9971 - expansion module user templates
toontech2000
Hello all,
I have a small office with 6 PA's who have expansion modules. the setup is, every PA needs to lines of every other person in the office so a call can be answered on their behalf. When someone new starts (or leaves) I have to manually amend each PA's profile to add or remove this person. Is there some sort of template we can create so that I only have to make the change in one area and the setting will take affect on all PA's module?
Thanks.
Chris Deren
You can use the propagate changes checkbox on the line to propagate the configuration to all shared DNs. Not sure what else you are looking for.
HTH,
Chris
