Community Member
9971 has unregistered cme 8.6
Hello everyone! Need  your help
I have 2811 with 8.6, also i have 9971(setup according to instructions). It can't register. Sometimes it registering and i can even call, but then it disconnects. In status, i see: ethernet disconnected,configuring ip.
when router starts:
Sep 10 08:27:26.219: VOICE REGISTER POOL-1 has unregistered. Name:SEPD824BD27AB82  IP:10.2.222.3  DeviceType:Phone
*Sep 10 08:27:49.671: VOICE REGISTER POOL-1 has registered. Name:SEPD824BD27AB82  IP:10.2.222.3  DeviceType:Phone
*Sep 10 08:28:09.519: VOICE REGISTER POOL-1 has unregistered. Name:SEPD824BD27AB82  IP:10.2.222.3  DeviceType:Phone
*Sep 10 08:28:36.591: VOICE REGISTER POOL-1 has registered. Name:SEPD824BD27AB82  IP:10.2.222.3  DeviceType:Phone
*Sep 10 08:28:44.211: VOICE REGISTER POOL-1 has unregistered. Name:SEPD824BD27AB82  IP:10.2.222.3  DeviceType:Phone
*Sep 10 08:28:46.787: VOICE REGISTER POOL-1 has registered. Name:SEPD824BD27AB82  IP:10.2.222.3  DeviceType:Phone
show running
Current configuration : 5697 bytes
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.2.222.250 10.2.222.254
ip dhcp pool ITS
network 10.2.222.0 255.255.255.0
option 150 ip 10.2.222.254
default-router 10.2.222.254
dns-server 10.2.222.254
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
  bind control source-interface FastEthernet0/1.11
  bind media source-interface FastEthernet0/1.11
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 10.2.222.254 port 5060
max-dn 10
max-pool 3
load 9971 sip9971.9-1-1SR1.loads
authenticate register
authenticate realm all
timezone 42
tftp-path flash:
file text
create profile sync 0001113296487642
network-locale RU
user-locale RU
camera
video
voice register dn  1
number 205
name Andrey
voice register template  1
feature-button 1 NewCall
feature-button 2 Trnsfer
feature-button 3 PickUp
feature-button 4 GpickUp
softkeys hold  Newcall Resume
softkeys idle  DND Pickup Gpickup Newcall Redial Cfwdall
softkeys connected  Confrn Endcall Hold
voice register template  2
softkeys idle  Cfwdall DND Gpickup Newcall Pickup Redial
softkeys seized  Cfwdall Endcall Gpickup Pickup
softkeys connected  Confrn Endcall Hold Park
voice register pool  1
id mac D824.BD27.AB82
type 9971
number 1 dn 1
template 2
dtmf-relay sip-notify
username 205 password 5
camera
video
voice-card 0
redundancy
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
encapsulation dot1Q 10
ip address 10.2.222.254 255.255.255.0
interface FastEthernet0/1.131
encapsulation dot1Q 130
ip address 10.2.0.254 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
tftp-server flash:9971/dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:9971/kern9971.9-1-1SR1.sebn
tftp-server flash:9971/rootfs9971.9-1-1SR1.sebn
tftp-server flash:9971/sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:9971/sip9971.9-1-1SR1.loads
tftp-server flash:9971/skern9971.022809R2-9-1-1SR1.sebn
debug tftp events
*Sep 10 09:32:23.459: TFTP: Looking for CTLSEPD824BD27AB82.tlv
*Sep 10 09:32:23.543: TFTP: Looking for ITLSEPD824BD27AB82.tlv
*Sep 10 09:32:23.635: TFTP: Looking for ITLFile.tlv
*Sep 10 09:32:23.879: TFTP: Looking for SEPD824BD27AB82.cnf.xml
*Sep 10 09:32:23.879: TFTP: Opened flash:/SEPD824BD27AB82.cnf.xml, fd 10, size 3960 for process 224
*Sep 10 09:32:23.895: TFTP: Finished flash:/SEPD824BD27AB82.cnf.xml, time 00:00:00 for process 224
Hi Andrey,
ethernet disconnect message is a cable issue, try to replace your network cable.
Anas
please rate all helpful posts
Community Member
Hello, Anas! It is the first thing that i did. I tryed another port, another cable, but its not help. when i press 'show video' button, all problems disappear and telephone registers well. Any ideas?
Hi Andrey,
can you disable video from the configuration and do a test
Anas
508
