9971 KEM issue with CME
I have an IP Telephny set up with CME running on version 9.1.We have an 8961 phone connected with 1 KEM .Actually we requied to connect 2 KEM for our recepetion and 8961 will support only 1 KEM .Thats why we purchased 9971 phone.
But when  connected 9971 with 2 KEM i got an error like " Your IP Phone do not have power to provide the accessory connected ".
From the following Power information showing that 9971 requires power adapter for connnecting 3 KEMS.
But it also mentoning that with POE it will work with 1 KEM.But I tried with 1 KEM but i am getting the same error.
Also mentioning with AT power it will support 2 KEMs....what is AT power I dont have any idea about that?
Is there any solution other power adapter for connecting 2 KEMs for 9971..we are having POE cisco switch....
Thanks in advance
Nithin Louis.
Power Information
The Cisco Unified IP Color Key Expansion Module for the Cisco Unified IP Phone 8961, 9951, and 9971 have the following power consumption and power scheme.
Power Consumption
48V DC, 5W per KEM
Power Scheme
At least one KEM can be powered up if the Cisco Unified IP Phone 8961, 9951, and 9971 uses AT PoE.
If the phone uses a power adapter, three KEMs can be powered up for the Cisco Unified IP Phone 9971, two KEMs can be powered up for the Cisco Unified IP Phone 9951, and one KEM can be powered up for the Cisco Unified IP Phone 8961.
A KEM cannot be powered up if the Cisco Unified IP Phone 8961, 9951, and 9971 uses AF PoE.
With AT power, the Cisco Unified IP Phones 9951 and 9971 can support two KEMs plus a USB headset or another USB device that is independently powered and only uses USB for signaling.
The Cisco Unified IP Phone 9971 needs a power cube to support three KEMS.
With AF power, the Cisco Unified IP Phones 9951 and 9971 need power cubes for any KEMS. The Cisco Unified IP Phone 8961 can support one KEM with CDP, AF power, and no power cube.
1 REPLY
Hall of Fame Super Red
Re: 9971 KEM issue with CME
Hi Nithin,
Excellent question!
802.03at is a standard of PoE that supplies a higher rating of up to 30W so that's why it can power the 2-KEMs
Cisco has been leading Power over Ethernet technology since 2000; the first generation
of Cisco prestandard PoE delivered up to 6.3W to the end devices over the Ethernet
cables that transport data traffic. This prestandard PoE supported endpoints such as
Cisco IP phone 7906G/7911G/7941G and so on.
In June 2003, the IEEE approved a standard, IEEE 802.3af, for Power over
Ethernet technology. The standard specified a 15.4W maximum power
delivery from the network device, also known as power sourcing equipment
(PSE), to an end device, also known as a powered device (PD). The average
maximum power available to the PD is 12.95W after accounting for cable loss.
This expands broader end device coverage such as Cisco IP phone 7941G-GE/7961G-GE/7985G
and wireless access points.
To support more emerging end devices with higher power requirements,
IEEE introduced new standard, 802.3at,  to scale up to 30W power delivery. This
further expands the end devices coverage to a broader range including
newer devices such as IEEE 802.11n wireless accesspoints, security
surveillance cameras, and so on. Cisco Catalyst 4500E was the first Ethernet
switch in theindustry to introduce 30W PoE technology in 2007, two years
before the IEEE 802.3at standard introduction, andlater become compliant
with the IEEE 802.3at standard when it was ratified in 2009.
From
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/white_paper_c11-670993.pdf
Cheers!
Rob
"Why do the best things always disappear "
- The Band
584
