Hello All,
I have some 9971 phones which can not reach the VM via the envelop button.
in 9971 phone's console log:
7035 NOT 15:17:30.559467 CVM-userio.Trace: [thread=AWT-EventQueue-0][class=cip.userio.InputManager] KeyEvent :: Key:Messages
7036 NOT 15:17:36.810612 CVM-Softkey is Released over : [thread=AWT-EventQueue-0][class=cip.app.n] Exit
7037 NOT 15:17:36.815923 CVM-Focus Base is class cip.comp.ao
7038 NOT 15:17:44.905342 CVM-userio.Trace: [thread=AWT-EventQueue-0][class=cip.userio.InputManager] KeyEvent :: Key:Messages
7039 ERR 15:17:44.909706 CVM-: [thread=messages MQThread][class=cip.msg.Messages] URL : device.settings.config.messagesurl
7040 NOT 15:17:46.043305 CVM-Softkey is Released over : [thread=AWT-EventQueue-0][class=cip.app.n] Exit
7041 NOT 15:17:46.050420 CVM-Focus Base is class cip.comp.ao
Here you can see the "messages" button has been pressed, but on the same moment it's been released.
I also have done some tests with a CIPC, which is working fine, I can reach VM via its envelope button.
If you dial the VM pilot number from the 9971, VM can also be reached.
Under phone services > voicemail service > ENABLE box is checked!
also tried update Subscription under this menu.
Any idea, experience?
Thanks in advance!
Tibor
