9971 registered to CME fails to call CUCM IP Phones
Hello guys,
I registered 9971 and CIPC+CUVA to CME 9.0 (c3900-universalk9-mz.SPA.152-2.T1.bin).
I also have a CIPC+CUVA registered to a CUCM 8.5.1.10000-26.
I try H.323 trunk and SIP trunk to connect the CME and CUCM.
CME CIPC+CUVA works flawlessly, it can call CUCM CIPC+CUVA either using H.323 trunk or SIP trunk (audio and video).
CUCM CIPC+CUVA can call to CME CIPC+CUVA either using H.323 trunk or SIP trunk (audio and video).
Unfortunately, CME 9971 cannot call to CUCM, neither using H.323 trunk nor SIP trunk, it just terminate the call (no busy tone or anything).
Later, I tried to register the CME to gatekeeper, and the CME 9971 can call another CME (audio only), but still, not to CUCM.
Have anyone tried this?  Is it possible for a CME 9971 to call CUCM phones?
Thank you for helping.
Christian
Hall of Fame Super Gold
It should be possible.
You may have a configuration problem but without seeing config or traces it's impossible to say which.
Hi Paolo, please check this configuration, thank you for your response.
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa session-id common
clock timezone WIB 7 0
no network-clock-participate wic 0
no ipv6 cef
ip cef
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 3600 min 120
voice class codec 1
codec preference 1 g729r8
voice register global
mode cme
source-address 10.205.27.100 port 5060
max-dn 10
max-pool 10
load 9971 sip9971.9-2-2SR1-9
timezone 43
create profile sync 0000551470218046
camera
video
voice register dn  1
number 8001
name John Chambers
label John Chambers
voice register dn  2
number 8002
name Michael Jackson
label Michael Jackson
voice register pool  1
id mac 001D.70FB.168B
type 9971
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username cisco password cisco
no vad
camera
video
voice register pool  2
id mac 44E4.D944.9BF6
type 9971
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
username cisco1 password cisco1
no vad
camera
video
voice translation-rule 1
rule 1 /^9$/ /8100/
rule 2 /^3958/ /8/
rule 3 /^3959/ /9/
voice translation-rule 2
rule 1 /^\([4-8]...\)$/ /395\1/
voice translation-profile LOCAL
translate called 1
voice translation-profile OUTGOING
translate calling 2
application
service aa flash:/CME/IVR/app-b-acd-aa-3.0.0.2.tcl
  param number-of-hunt-grps 1
  paramspace english index 1
  param handoff-string aa
  param dial-by-extension-option 1
  paramspace english language en
  param max-time-vm-retry 2
  param max-extension-length 4
  param aa-pilot 8999
  paramspace english location flash:/CME/IVR/
  param second-greeting-time 30
  param welcome-prompt _bacd_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 60
  param voice-mail 8100
  param service-name queue
service requestpin flash:/CME/SCRIPTS/requestpin.tcl
  param uid-len 5
service queue flash:/CME/IVR/app-b-acd-3.0.0.2.tcl
  param queue-len 10
  param aa-hunt1 8100
username cisco password 0 cisco
username 12345 password 0 111111
ip address 10.205.27.100 255.255.255.0
ip pim dense-mode
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id CME-9971 ipaddr 10.204.206.252 1719
h323-gateway voip h323-id CME-9971
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 10.205.27.100
ip route 0.0.0.0 0.0.0.0 10.205.27.1
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-1/dkern9971.100609R2-9-2-1.sebn alias dkern9971.100609R2-9-2-1.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-1/kern9971.9-2-1.sebn alias kern9971.9-2-1.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-1/rootfs9971.9-2-1.sebn alias rootfs9971.9-2-1.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-1/sboot9971.031610R1-9-2-1.sebn alias sboot9971.031610R1-9-2-1.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-1/sip9971.9-2-1.loads alias sip9971.9-2-1.loads
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-1/skern9971.022809R2-9-2-1.sebn alias skern9971.022809R2-9-2-1.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-2SR1-9/dkern9971.100609R2-9-2-2SR1-9.sebn alias dkern9971.100609R2-9-2-2SR1-9.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-2SR1-9/kern9971.9-2-2SR1-9.sebn alias kern9971.9-2-2SR1-9.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-2SR1-9/rootfs9971.9-2-2SR1-9.sebn alias rootfs9971.9-2-2SR1-9.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-2SR1-9/sboot9971.031610R1-9-2-2SR1-9.sebn alias sboot9971.031610R1-9-2-2SR1-9.sebn
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-2SR1-9/sip9971.9-2-2SR1-9.loads alias sip9971.9-2-2SR1-9.loads
tftp-server flash:/CME/FIRMWARES/cmterm-9971.9-2-2SR1-9/skern9971.022809R2-9-2-2SR1-9.sebn alias skern9971.022809R2-9-2-2SR1-9.sebn
sccp local GigabitEthernet0/0
sccp ccm 10.205.27.100 identifier 1 version 7.0
sccp
sccp ccm group 1
dial-peer cor custom
name all
name fac
dial-peer cor list ALL-CALL
member all
member fac
dial-peer cor list FAC-Required
member fac
dial-peer voice 1 voip
corlist incoming ALL-CALL
translation-profile incoming LOCAL
incoming called-number .
voice-class codec 1
no vad
dial-peer voice 2 voip
shutdown
session protocol sipv2
no vad
dial-peer voice 11 voip
description IVR
service aa
destination-pattern 8999
session target ipv4:10.205.27.100
incoming called-number 8999
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 61 voip
description Outgoing Call to Other Branch
translation-profile outgoing OUTGOING
shutdown
destination-pattern 3.T
session target ras
voice-class codec 1
no vad
dial-peer voice 62 voip
description SIP Outgoing Call to CUCM
destination-pattern 3988888
session target ipv4:10.204.27.222
no vad
gateway
timer receive-rtp 1200
telephony-service
video
no auto-reg-ephone
max-ephones 10
max-dn 10
ip source-address 10.205.27.100 port 2000
service phone videoCapability 1
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 04 2012 11:42:00
ephone-dn  1  dual-line
number 9001 no-reg both
label Tom - 9001
name Tom
ephone  1
video
mac-address AAAA.AAAA.AAAA
type 7975
button  1:1
Need traces to see why call if failing.
Hi Paolo,
What traces do you need?  CUCM traces or CME debugs?  Thanks.
Christian
You should look the CME traces to begin with.
Anyway to be honest with you, this kind of issues are better dealt with the TAC. Discussion in a public forum cannot replace their work.
Hi Paolo,
Thanks for the suggestion, unfortunately, this is just a Proof of Concept for a customer, so I can't involve TAC at the moment, but I think I'll try contacting local Cisco engineer.
Please contact me if you hear something about this.  Thanks.
Christian
Hi Christian,
Where you able to solve this issue??
Rgds
- Victor
Hi Victor,
Several days and restarts later, the call suddenly worked.  I didn't think I made any change to the configuration.  Maybe it's just a glitch or something.  Until now, I've been facing many weird problems with CME and 9971, if there's anybody successfully using this combination, please share your experience here.  Thank you.
Christian
1518
