9971 video Call
Hi all...
Does 9971 video call works between Cisco IP Phone only?
Thanks.
Re: 9971 video Call
Hi ,  The 9971 should work with any other endpoint registered to the CUCM with video capability or any Video endpoint connected via H.323 or SIP trunk with H.264 video capability.  I hope this helps.  Marcos
Re: 9971 video Call
It means 9971 doesn't work with Skype? Am I correct?
Thanks.
Re: 9971 video Call
The first problem is the call control. The CUCM works with SIP and SCCP to communicate with endpoints. The traditional Skype uses a proprietary protocol, so it wouldn't work with CUCM.  If you are talking about the Skype for SIP, it should be able to register the Skype for SIP to the CUCM and it should be able to place and receive calls, but afaik the Skype for SIP does not support video. I hope this clarify a little bit. Thanks, Marcos
Re: 9971 video Call
Marcos, thanks for your explanation
Thanks..
916
