A dial plan question
SRND at http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806375f2.html#wp1044818
in the section:
Deploying Variable-Length On-Net Dial Plans with Partitioned Addressing
and the subsection within it:
Inter-Site Calls Within a Cluster:
translation_pt 91212555.1xxx to be translated to 1xxx
and another sub-section
Outgoing PSTN and IP WAN Calls:
LD RP: 9.1[2-9]xx[2-9]xxxxxx
If you look at these two, there seem to be a big problem with this solution in the case IP wan goes down, the IP phones in the HQ where CCM exist are not able to call the remote office 2125551xxx through pstn because call always will look for 91212555.1xxx and translate to 4 digits but they are unregistered already and should went into SRST mode. But the call manager can not route the call at all unless there is a feature allows CCM to do this if the phone is down and it will detect it and route to pstn? Is this a new feature in CCM 5.x?
Re: A dial plan question
Beginning with CCM 4.2 there is a new DN level setting - Call Forward Unregistered. So, if the phone is unregistered, you can configure a different number to send the call to. In this case, if the phone is operating in SRST mode, you can send the call out to the PSTN.
Hope this helps. If so, please rate the post.
Brandon
Thankd Brandon. I think I heard this before in one of the Cisco seminar. But I am looking at CCM 5.11 line forward configuration I don't see this option. Attached is a snapshot from my lab CCM 5.11.
CM 5.1 doesnt follow 4.2 feature set. It follows 4.1 feature set. You will see this forward option in 6.0 and moving forward.
Sankar
PS: please remember to rate all posts!
Sankar
Thanks. I did find this on CCM6.0. Now my question is: If you look at my initial qeustion, do you think this is a design flaw for CCM 5.x since it is from 5.x srnd?
171
