A doubt with TRules and Dial-peer
Hi, the end customer want to add a prefix in all outbound calls to mobile and fix national calls.
In the dial-peer pots for mobile and fix i add a "prefix 107077" when i put for example "sh dialplan number 0630112233" this is the output:
UC560_Valencia#sh dialplan number 0630112233
Macro Exp.: 0630112233
VoiceEncapPeer80
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `**CCA*Spain*Mobile**',
        tag = 80, destination-pattern = `06........',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=3,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 80, Admin state is up, Operation state is up,
        Outbound state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:call-national-plus
        Translation profile (Incoming):
        Translation profile (Outgoing):OUTGOING_TRANSLATION_PROFILE
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
        mailbox selection policy: none
        trunk-group:
        id = `ALL_T1E1', preference = `'
        type = pots, prefix = `107077',
        forward-digits all
        session-target = `', voice-port = `',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        preemption level = `routine'
        bandwidth:
            maximum = 64 KBits/sec, minimum = 64 KBits/sec
        voice class called-number:
            inbound = `', outbound = `'
        dial tone generation after remote onhook = enabled
        mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
        snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 639726, Charged Units = 0,
        Successful Calls = 44, Failed Calls = 9, Incomplete Calls = 2
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "1   ",
        Last Disconnect Text is "unassigned number (1)",
        Last Setup Time = 1219921859.
        Last Disconnect Time = 1036116868.
Matched: 0630112233   Digits: 2
Target:
the dial-peer voice 80 configuration is:
dial-peer voice 80 pots
trunkgroup ALL_T1E1
corlist outgoing call-national-plus
description **CCA*Spain*Mobile**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 06........
forward-digits all
prefix 107077
no sip-register
voice translation-rule 4
rule 15 /^.*$/ /96xxxxxxx/
voice translation-rule 5
rule 1 /96xxxxxxx/ /7998/
voice translation-rule 6
rule 1 /96xxxxxxx/7998/
voice translation-rule 7
rule 14 /^70\(..\)$/ /96xxxxxxx/
rule 15 /.*/ /91xxxxxxx/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 2 /^0/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_FXO
translate calling 7
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile entradagral_Called_5
translate calling 3265
translate called 5
voice translation-profile entradaresto_Called_6
translate called 6
voice translation-profile nondialable
translate called 1000
trunkgroup ALL_T1E1
preference 3
forward-digits all
prefix 107077
no sip-register
I did the same for the dial-peer fix calls.
Question is , there is some Translation Rules, and i dont know if these will change the prefix after the dial-peer or before, or will do nothing and with this configuration is ok.
These are the Trules:
rule 1 /.*/ //
rule 2 /^0/ //
translate calling 7
translate calling 4
translate called 5
translate called 6
These are appied to dial-peer,  TR 1000 and 1112 are in incoming calls ("translate CALLED") so there will be no more changes in the outbound calls, and TRules for outbound calls, number 7, 4, and 3265 change all for national number 96xxxxxx.
Question is, there will be another change after the prefix in dial-peer?? or first make the prefix in dial-peer and after it apply change of Trules, so the prefix will be changed.
whats the order, first dial-peer and second Trules? or first Trules and second dial-peer?
And which will be the number send to operator with this configuration??
Regards!
Hall of Fame Super Silver
You need to realize that all numbers in destination pattern that are explicitly matched will be stripped, so in your case 06 gets stripped, if that is not your intent, your prefix needs to be 10707706
Chris
Ok, but i have one doubt, in the dial-peer there is the command forward digits all, so, 06 will be already forwarded, or not?
Yes, if you have forward-digits all then you are good.
Translation is taking place after the destination-pattern match.
Chris
Hi!
So the prefix in a dial-peer is only usefull when there is not any TR later, so in my case as I have TR the prefix will be deleted.
The TR for calling number are 4 and 7
So if for example in TR 4 I change rule 15 with:
rule 15 /^.*$/ /10707796xxxxxxx/
with this change the prefix 107077 for any call, mobile or fix, will be added, are you ok??
Thanks!
152
