a few quesions about CCM
I have a few questions need to be clear:
There are a few items under "System" menu bar: Server, callmanager and call manager group. What is the difference between server and call manager?
Mu understanding is server is callmanager.
The concept of cluster and publisher and subscriber: If I install a Callmanager on the first server with SQL server, I can assign it as primary call manager and Publisher. then if I need to install another callmanager on the second server, I will assign it as backup call manager, does that mean the second server also subscriber?
thanks for your help
Re: a few quesions about CCM
Server is where you update the HostName/IP Address, MAC and description of each server.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/b02servr.htm
Call Manager is where you set a number of configuration items for the Call Manager such as directory numbers, partitions etc.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/b02ccm.htm
Please refer to the CCM installation guide for your questions on publisher vs subscriber installations.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/install/instcall/cm413ins.htm
i have read the documentation before I post my question. Please give me more detailed explanation. thanks
The second server will become a subscriber if you configure it to become of a subscriber of the publisher.
There is some configuration work that needs to be performed for the CCM instance to become a subscriber.
There is a subscriber radio button, publisher IP address, passwords sync. This is all expained in the CCM installation guide under installing the publisher and subscriber databases.
I hope that clears things up for you.
tell me one thing where do the controls come are they coming from the subscriber or the publisher & one more thing we are using "Distributed voice gateway with distributed call treatment and queing using unified CVP ".
102
