Community Member
A problem with MWI Light that does not flash when message is waiting
WMI, is not an easy thing to understand and to configure. I have just solved the problem for receiving messages, and now the WMI does lignt on when there is a message for a user. So it must be some glich, because I think that I put everything correctly for WMI.
I attach my config files so someone can help me find my problem.
Thank you.
Re: A problem with MWI Light that does not flash when message is
Are the phones running SIP or skinny ?
If your extensions are 2 digits, your MWI on number should be 57.. and MWI off number should be 87..
Sankar
PS: please remember to rate posts!
Community Member
Hi, I am not completely certain that my phones uses SCCP. Thoug in all the config I have made, I work thinking that they where SCCP. How can I make shure ?
Also, I have tried what you said addng the following commands.
"no ephone-dn 19 dual-line
ephone-dn 19
no call-forward busy 99
no call-forward noan 99 timeout 18
number 57
mwi on
no ephone-dn 20 dual-line
ephone-dn 20
number 87
mwi off
But there is still no blinking red light on the phone that I leave a message on (ie 57).
So there is probably a miss configuration between sip and SCCP ? Or I dont' know what exacly.
Thank you for for your continuing help
Hall of Fame Super Silver
As Sankar said make sure you include the ".." such as number 57.. if your extensions are 2 digit long.
Take a look at this doc (page 14)
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/cmeinter/cue_cme1.pdf
HTH,
Chris
Community Member
Thank you very much.
The lights are on,
but your not home,
your mind
is not your own.....
Oups, got a little excited....!!
Bronze
121
