A symbol to delay dial
In traditional fax/modem ,we can use ',' to delay dial action to waiting for greeting or fax signal,or remote respond.
For example:
when we dial 11111111,,,801,dial action will send 11111111 and wait 3 seconds ,then send 801.
Is there a same function symbol to added in prefix or mask in CUCM or CME?
2 ACCEPTED SOLUTIONS
Re:A symbol to delay dial
On CUCM only for speed dials an you need 9.1+
Sent from Cisco Technical Support Android App
java
if this helps, please rate
www.cisco.com/go/pdi
An additional resource about this to add to Jaime's post, https://supportforums.cisco.com/docs/DOC-29944.
java
Re: Re:A symbol to delay dial
Thanks.
Do you have any idea how to use it in Cisco Jabber?
You cant, speed dials are a phone feature.
java
151
