A/V scanning CUCM4.x- Exclude any files?
I'm trying to find if there are any folders/file to exclude when performing a virus scan.
1 ACCEPTED SOLUTION
Re: A/V scanning CUCM4.x- Exclude any files?
You'll want to exclude the trace folders c:\program files\cisco\trace\ or you'll likely see high CPU on your system which can impact call processing.
Thanks for your response.  Do you know where the documentation is
that shows this?
241
