AA CUE Directory assistance
Hi Everyone,
I have
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 16:21 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
with
------------------ show software versions detail ------------------
Cisco Unity Express version (7.0.6)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc.
Applications:
Name: Installer (7.0.6.0)
Desc: Installer application
Type: (installer)
Desc: Service Engine Thirdparty Code
Type: (application)
Name: Bootloader (Primary) (2.1.14)
Desc: Service Engine Bootloader
Type: (bootloader)
Desc: Service Engine Infrastructure
Type: (application)
Desc: Global manifest
Type: (application)
Name: GPL Infrastructure (7.0.6)
Desc: Service Engine GPL Infrastructure
Type: (application)
Name: Voice Mail (7.0.6)
Desc: Voicemail application
Type: (application)
Name: Bootloader (Secondary) (2.1.14.0)
Type: (bootloader)
Desc: Service Engine OS Core
Type: (application)
Name: Auto Attendant (7.0.6)
Desc: Service Engine Telephony Infrastructure
Type: (application)
Components:
Name: CUE Voicemail Language Support (7.0.6)
Desc: Languages global pack
Type: (plug-in)
Name: CUE Voicemail US English (7.0.6)
Desc: English language pack
Type: (plug-in)
I have cobbled together two CUE scripts.  They have validated and "work" on the AA but I need help with the following problems
1.  when the scripts to directory portion the caller cannot interrupt the sequence.  I would like to add and option after the entry where the caller can press "1" to dial the number.
2. once the directory has finished the script just hangs up the phone.  I would like it to default back to operator...ext 890
1 REPLY
Hall of Fame Super Gold
CUE scripting, as any other programming, requires patience in writing and debugging.
In my opinion that's asking too much for something that need to work quick and may be changed often.
So I wrote an "universal AA" CUE script that supports the most common requirements, including what you mentioned, with only parameters configuration.
It can be acquired at www.ciscoscripts.com
293
