AA in CME not working
i am having some trouble with AA, setting are as below
CME+ AA                      5 port FXO
29XX-----------Tunnel-------VG 29XX
Phones
External caller are able to call the operator under connection plar command.
Internal extension to AA is working fine with prompts and call flow.
External callers hear a fast busy tone and following message on debug dial peer
Jan 14 11:39:58.630: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identifier already present in the list of currently handled calls. It is being refused.
any assistance?
Nasir
VG config
voice-port 0/1/1
trunk-group Trunk1
supervisory disconnect dualtone mid-call
supervisory custom-cptone SYD1
supervisory dualtone-detect-params 1
input gain 6
cptone BE
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 1999
impedance complex2
description Outside Calling STC Number 013-830-4658
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
dial-peer voice 1 pots
trunkgroup Trunk1
description out going calls from this POTS
destination-pattern 9T
dial-peer voice 10 voip
destination-pattern 1000
session target ipv4:172.10.1.1
dial-peer voice 11 voip
destination-pattern 1999
CME Config
application
service aa flash:its-CISCO.2.0.3.0.tcl
  param operator 1000
  paramspace english language en
  paramspace english index 1
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 1999
dial-peer voice 999 voip
service aa
destination-pattern ^1999$
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Everyone's tags (4)
Browse thru this link and see if you can get it working:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080566c4a.shtml
Voice CCIE #37771
I dont have CUE in this setup. Only need a drop thru mode. which is not working.
Nasir
can you trying shutting this dial-peer and make a call
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
This is a test dialpeer on the VG as mentioned above in the small topology diagram to verify that my calls are reaching the proper location. else the call will not reach to AA which resides on CME.
regards,
Nasir
Re: AA in CME not working
Cisco Unified CME B-ACD with Drop-Through Option: Example
The following example sets parameters for an AA service called aa and a call-queue service called callq. The direct-dial number to reach the AA service is 800 555-0100. Callers to this number drop through to the ephone hunt group that has a pilot number of 5071 after hearing the initial prompt from the file en_dt_prompt.au.
dial-peer voice 1000 pots
service aa
port 1/1/0
incoming called-number 8005550100
ephone-hunt 10 sequential
pilot 5071
list 5011, 5012, 5013, 5014, 5015
timeout 10
application
service callq tftp://192.168.254.254/user1/CallQ/B-ACD/app-b-acd.tcl
param queue-manager-debugs 1
param aa-hunt1 5071
param number-of-hunt-grps 1
param queue-len 10
service aa tftp://192.168.254.254/user1/CallQ/B-ACD/app-b-acd-aa.tcl
paramspace english location tftp://192.168.254.254/user1/prompts/
paramspace english index 0
param aa-pilot 8005550100
param service-name callq
param handoff-string aa
param second-greeting-time 60
param drop-through-option 1
param drop-through-prompt _dt_prompt.au
param call-retry-timer 15
param max-time-call-retry 700
param voice-mail 5000
param max-time-vm-retry 2
Attached is a doc with all different scenarios.
Voice CCIE #37771
can you post show run from both VG and CME.
Br,
Nadeem
Hi got it working under this setup.AA shifted to VGW But now the new issue is that input from the user is always triggering "en_dest_unreachable.au" prompt regardless of internal or external call.
CME                                       AA + 5 port FXO
Phones
Hi Any idea what does this means.
i am punching the numbers its matching the DP but not forwarding to the next hop router.
*Jan 14 14:18:39.623: //17031//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
ANI
DNIS 1999
No DNIS
*Jan 14 14:18:45.219: //17031//TCL :/tcl_PutsObjCmd:
proc act_GotDest
Call failed.  Play prompt and collect digit
proc act_Select
It worked with the following setup i was missing some commands under the voice service voip for the 2nd call leg.
voice service voip
every thing works..
Well done!
Voice CCIE #37771
446
