01-16-2008 05:03 PM - edited 03-15-2019 08:16 AM
I am new to TCL scripts and i am looking for an example of a simple AA TCL script that goes something along the lines of press 1 for person A, press 2 for person B etc.
01-16-2008 07:37 PM
Search for app-b-acd on the cisco website. I wouldn't recommend running the latest version on express 4.2 as I couldn't get it to load and had to downgrade to 4.1 to make it work. The same version & config worked fine once I downgraded so I would think to call 4.2 buggy. The documentation in the tar file has an example configuration.
01-17-2008 07:29 AM
Which exact IOS version you has problems with ?
For example CSCsj97535 is fixed in XW3.
