12-14-2006 06:32 AM - edited 03-14-2019 07:13 PM
we have deployed AAR in our scenario.
All is working fine except one thing.
IP Phone (location A) is calling IP Phone (location B), no bandwidth rerouting via ISDN (location A)
Ip Phone (location A) is calling IP Phone (location B), which has been call forwarded all to an external number, no bandwidth, busy signal no rerouting.
Any thoughts on this?
thanks August
12-14-2006 08:50 AM
The Call Forward All is invoked before the AAR. So the Site A phone doesn't call Site B phone then get forwarded. So this is what I think is happening. What it does is it sends the request to CCM, it sees the CFA, then processes that with the CFA CSS. The call then is setup but more than likely is going against a Site B Gw (this is dependant on the CSS applied above). Since the Site B is congested it then tries to use AAR, this is assuming the site B gateway is added as an AAR group. That AAR group is probably 91 prefix, at least that's the most common NANP way to do it. This appends this to the CFA number, which probably already had a 91xxxxxxxxxx. So the call is probably going out with 9191xxxxxxxxxx. Now of course CFA might not even work with AAR at all, which might be the other scenario since AAR groups append to External Phone Masks and I've read nothing about CFA. Another scenario might be the Gateway doesn't have an AAR group assigned.
Assuming my guess on how CFA and AAR is right, then there should be a simple way to test this. Just change the CFA on the phone to not include the AAR group prefix. Sure this won't work for normal calling but it will let us test AAR correctly. If that ultimately is the issue then you can use a AAR-CSS on the phone with a pattern in that CSS to account for the 91 overlap. Again this is just theory on my part.
I'm going to lab this out today because frankly I'm not entirely sure what it will do other than it will definitely process the CFA and not the AAR to the phone. I will let you know my results.
Please rate any helpful posts
Fred
12-15-2006 03:44 PM
Ok heres the deal with this. Some of my assumptions were wrong from the last post.
After you hit CCM and it processes the CFA, then it looks up the pattern in it's CFA CSS. This pattern then checks it's route list and selects the gateway. The site B gateway is going to be probably the first gateway in your route list, assuming Location has been set on the gateway then the call will fail. But if you add a second gateway, say from the site A, then the call will use that and succeed. AAR never gets invoked, but the Location setting is what affects the failover in the route list.
So in my testing I was able to get a busy signal on my CFA call if I only had site B gateway in my routelist and a location set. As soon as I added site A gateway as a secondary on my routelist the call would go through on site A gw. If I removed the Location setting from site B gw then site B would be the 1st selected gw on my CFA call. So with well crafted CSS for CFA and Route Lists with redundancy you can do this correctly. Unfortunately since it's by Route List level and not pattern then this makes it harder to make best routing decisions for a large complex rollout.
Hope this helps.
Fred
