03-05-2007 03:22 PM - edited 03-14-2019 08:19 PM
Hi Peers,
just wanting to ask your thoughts on config of AAR.
We have our region and locations available, but wanted to know:
Once the AAR group is created, is assigning the AAR group only though each DN? (meaning BAT tool to apply to all?) or is there somewhere which i haven't seen to add to a Partition etc.
Secondly can you confirm AAR will not work if the WAN link goes down? And thats when Route Lists come in?
Much appreciated
03-05-2007 03:42 PM
Yes, AAR groups are applied to gateways, voicemail ports and DNs. You need to make sure that the phones have their external phone number masks properly set and the AAR group definitions have the proper prefix (9, 91 etc) set.
AAR doesnt work when wan goes down, although with CCM 4.2 and forward (not in 5.0) you can Forward on not register option to divert calls through the PSTN
03-05-2007 04:44 PM
Thanks Shanky!
We have CCM5, so i supposed to auto route calls via PSTN when the WAN is down is through Route Groups. Would you agree?
THanks again
03-05-2007 07:31 PM
That's incorrect, AAR only kicks in when the Location bandwidth has been exhausted. CCM 5.X has not intruduced any new workaround for WAN outage. In fact CCM 4.2 has a new feature "call forward on unregistered" where you can re-route calls when a phone unregisters with CCM, such as in case WAN outage.
Route List/Group will not achive your desired outcome, when WAN goes down, phones unregister, and when you dial the phone's DN it will always be best match, before CCM will start looking at route patterns, hence the new feature in 4.2.
Chris
03-05-2007 10:10 PM
cderen, thanks for that
and you are correct it wouldn't. I apologise as i have not painted the desired picture for you.
We have 1 cluster with a remote branch site connecting to CCM via WAN .
If the WAN is down, SRST (which we have configured) will kick in for the Branch office and route to PSTN. From HQ however, if AAR is not effective in this situation, is it correct in saying the Route list/Route Groups are responsible for this?
03-06-2007 07:58 AM
No, you will need to dial the full phone number, the 4 digit or whatever your dialplan is will not work, unless you have CCM 4.2 or 6.0 (coming out soon) where you can do call forwarding on unregistered, which would be set to the full phone number. It will simply go to VM or whatever you have set for call forward busy/no answer.
HTH, please rate all useful posts!
Chris
03-28-2007 12:19 AM
Hi Guys.. Just finally on this topic. I have done as much as the following and not sure if i have done this correctly
(as you know we have WAN between HQ and the Branch site. Branch site relies on the CCM in HQ, but has SRST if loses connection)
In order to seamlessly route to PSTN
At HQ:
I've set a test phone in HQ to AAR 1 group
I've set the test phone to be in the AAR_CSS1
I've set the gateway in HQ to AAR 1 group
At BRANCH:
I've set a test phone in Branch to AAR 2 group
I've set the test phone to be in the AAR_CSS2
I've set the gateway in HQ to AAR 2 group
AAR group prefix have been set as: 0 for outside line (australia) and the remaining area code to complete the 10 digits?
eg.. prefix: 0088901
will this work? We use 4 digit dialling so i assumed adding the prefix of auth code plus area code.
Is the above efficient to get successful AAR?
If you can help me... Your a champ!
