AAR failure
I need to know if I must configure AARgroup in both DN's (remote and central site dn's) or if aar works if I configure aargroup in remote side only.
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: AAR failure
Yes, once you have more then 2 sites then you can still be fine with a single AAR group as long as the prefix between the sites is the same i.e. 91.
If you have 3 sites for example and between site A and B you dial 10 digits not 11, but between sites A and C and B and C you dial 11 digits then you have to create 2 AAR Groups:
AAR_10_Digits
prefix within group 9
prefix to AAR_11_Digits 91
AAR_11_Digits
prefix within group 91
prefix to AAR_10_Digits 91
the all DNs in site A and B will use AAR_10_Digits and DNs at site C will use group AAR_11_Digits
HTH, please rate all posts!
Chris
Re: AAR failure
You need it on both as that is how the AAR prefix is determined. It's using a prefix specified between 2 or in your case 1 AAR Group.
Chris
Re: AAR failure
Cris, then Can I configure both phones(local and remote) with a single aargroup?
Thanks in advance.
Walter
Re: AAR failure
AAR_10_Digits
AAR_11_Digits
Chris
142
