08-16-2013 02:16 PM - edited 03-16-2019 06:54 PM
I'm trying to setup AAR fucntionality but its not working
I did the right steps but after testing i can see the call goes out of the gateway but i hear a busy tone.
What i did was the following:
Created aar partitions
Created aar css's
created aar group
created route pattern and route list for aar.
Enabled AAR in service parameters to => true
I'm testing between 2 sites ( registered to UCM ) site a & b
In 2 sites i applied AAR group to the DN's
In site XX i applied AAR to the phone itself
i point the router pattern to the partition which i've created earlier ( pt-aar)
also the route list (rl-aar)
checked ( calling party external phone numbers mask)
transform mask===> XXXXXXXXXX ( 10 dgits)
Predot ( national - isdn)
If i reduce the bandwith in the locations i receive the message on my phone ( Network congestion rerouted)
after that i receive a busy tone so thats means its not rerouting out of the pstn as a long distance call.
I've also resetted the gateways in UCM, resyncd the bandwith no success
Here is my output of the gateways:
SiteA-RTR#
Aug 16 22:02:23.827: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0002
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Display i = 'SiteA Phone 1'
Calling Party Number i = 0x0081, '2025552001'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '4083873002'
Plan:ISDN, Type:National
Aug 16 22:02:23.867: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8002
Aug 16 22:02:23.923: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8002
Cause i = 0x8281 - Unallocated/unassigned number
Aug 16 22:02:24.499: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0002
Aug 16 22:02:24.507: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8002
SiteB-RTR#
Aug 16 22:02:23.863: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0085
Standard = CCITT
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2181, '2025552001'
Aug 16 22:02:23.863: ISDN Se0/2/0:23 Q931: Received SETUP callref = 0x8085 callID = 0x0006 switch = primary-ni interface = User
Aug 16 22:02:23.879: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8085
Aug 16 22:02:23.883: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8085
Cause i = 0x8081 - Unallocated/unassigned number
Aug 16 22:02:23.895: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0085
Aug 16 22:02:23.895: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8085
Solved! Go to Solution.
08-19-2013 04:02 AM
From debug you can have a clear vision that incoming dial-peer being selected is dial-peer 1 and that dial-peer doesn't do any kind of modification.
Try to implement below solution and test.
voice-port 0/2/0:23
translation-profile incoming PSTN
exit
voice translation-rule 100
rule 1 /.*\(3...\)/ /\1/
exit
voice translation-profile PSTN
translate called 100
exit
08-19-2013 04:28 AM
Great that it worked.
Actualy the problem is with the lack of configuration.
As your SiteB gateway is H.323 gateway and gateway is sending call to CUCM with help of 2 voip dial-peers with destination-pattern 3... and the call coming from pstn was of 10 digit.
So to match that voip dial-peer you have to convert 10 digit to 4 digit so that required extension can be triggered.
08-17-2013 07:18 AM
Are you allowed to dial this 408 number as 10 digits? Did you try as 11 digits? Can you call this number from the phone?
Chris
08-17-2013 08:17 AM
Hi Chris,
I tried it,
Get the same thing busy tone but thats because i don't have an existing routepattern/dial-peer
08-17-2013 08:19 AM
Area code 408 requires 11 digit dialing, see:
http://www.nanpa.com/enas/area_code_query.do
so, make sure your AAR group prefixes 1 (along with off-net access code if dial-peers/route patterns have it).
Chris
08-17-2013 08:47 AM
chris,
i'm sorry but i'm not following you
forgot to mention this is for lab purposes
08-17-2013 08:56 AM
You are sending the call with 10 digits instead of telco expected 11, hence the telco unallocated error, you need to prefix 1 via the AAR group.
08-17-2013 09:04 AM
Chris,
Thanks for your quick reply..
I wil try this and let you know right nowe not at home.
08-18-2013 04:52 AM
Hi chris,
If i put 1 as prefix in the aar group the call doesnt even to attempt
to come in the gateway.
i"ll send some screenshot of my rp
that points to the gateway
08-18-2013 06:15 AM
Can you please share what gateway you are using for Site A and Site B?
Because your Site B gateway receives the call from Site A via PSTN and then releases the call as " Unallocated / unassigned number".
Also if possible do share RTMT detailed trace for the same call.
08-18-2013 06:49 AM
Hi nishant
Site A is an MGCP gateway
Site B is an H323 gateway
the routelist i've created is based on standard local route group.
The routepattern that i've created ( \+1.408387XXXX ) points to this routelist
I'm not using TEHO for this construction
specs RP:
Calling party checked ( XXXXXXXXXX) 10 digits
Called party ( Predot)
With National /ISDN
Enough info?
08-18-2013 07:27 AM
If you are stripping preDot (+1) how are you sending the 1 to telco then? You should not strip pre dot for this call and need to ensure you have proper dial peer on the GW that matches it.
HTH,
Chris
08-18-2013 07:56 AM
still not working
9.1408387XXXX
dial-peer voice 1 pots
destination-pattern 9[1-9].........
port 0/2/0:23
forward-digits all
08-18-2013 08:36 AM
I think the extension for SiteB Phones will be of 4 digit..right?
Where you are doing digit manipulation? I mean at router level or in CUCM?
Try to run debug voice ccapi ind 2 and debug h225 asn1 in SiteB router so that you can confirm yourself what digits you are sending towards CUCM.
Have you applied any translation-rule in Site B router? Please do share it if any
08-19-2013 03:40 AM
Hi nishant i have some voice translation rules configured on my siteB router.
I will send you the running config.
output of debug voice ccapi and h225 doesnt give me more info
SiteB-RTR#
Aug 19 11:26:23.336: //-1/03355D9E8004/CCAPI/cc_api_call_setup_ind_common:
Interface=0x68B7244C, Call Info(
Calling Number=2025552001,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=4083873002(TON=National, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
SiteA-RTR#sh run
Building configuration...
Current configuration : 3005 bytes
! Last configuration change at 06:11:32 EST Mon Aug 19 2013
version 12.4
hostname SiteA-RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone EST -5
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice-card 0
archive
log config
hidekeys
controller T1 0/2/0
pri-group timeslots 1-8,24 service mgcp
controller T1 0/2/1
channel-group 0 timeslots 1-24
description WAN CONNECTION
interface Loopback0
ip address 10.10.110.1 255.255.255.255
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.101
encapsulation dot1Q 101
ip address 10.10.100.1 255.255.255.0
interface FastEthernet0/0.102
encapsulation dot1Q 102
ip address 10.10.200.3 255.255.255.0
ip helper-address 10.10.210.10
interface FastEthernet0/0.103
encapsulation dot1Q 103
ip address 10.10.210.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
description network connection to SB router
ip address 10.10.111.1 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
no fair-queue
interface Serial0/1/1
description network connection to Branch2 router
ip address 10.10.112.1 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/2/1:0
no ip address
interface Serial0/3/0
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager switchback immediate
ccm-manager redundant-host 10.10.210.10
ccm-manager mgcp
ccm-manager fax protocol cisco
mgcp
mgcp call-agent 10.10.210.11 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
port 0/2/0:23
forward-digits 10
gatekeeper
zone local GK ipexpert.com 10.10.100.1
zone remote backbone ipexpert.com 10.10.100.2 1719
zone prefix backbone 011*
no shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
login
transport input telnet
scheduler allocate 20000 1000
ntp source Loopback0
ntp master 5
ntp server 10.10.100.2
end
SiteB-RTR#sh run
Current configuration : 3898 bytes
version 12.4
hostname SiteB-RTR
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone PST -8
dot11 syslog
ip source-route
ip dhcp excluded-address 10.10.201.1 10.10.201.119
ip dhcp excluded-address 10.10.201.131 10.10.201.254
ip dhcp pool SB
network 10.10.201.0 255.255.255.0
default-router 10.10.201.1
option 150 ip 10.10.210.11 10.10.210.10
ip cef
ip domain name proctorlabs.com
no ipv6 cef
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
rule 1 /^3...$/ /408387\0/
voice translation-rule 7
rule 2 /^2...$/ /202555\0/ type any national plan any isdn
voice translation-profile 7
translate calling 7
voice translation-profile strip
translate called 1
voice-card 0
archive
log config
hidekeys
controller T1 0/2/0
pri-group timeslots 1-4,24
controller T1 0/2/1
interface Loopback0
ip address 10.10.110.2 255.255.255.255
ip ospf network point-to-point
h323-gateway voip bind srcaddr 10.10.110.2
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
switchport trunk native vlan 201
switchport mode trunk
switchport voice vlan 202
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
no ip address
encapsulation hdlc
isdn map address ^[2-9]......$ plan unknown type unknown
isdn bchan-number-order ascending
isdn outgoing display-ie
no cdp enable
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
ip address 10.10.111.2 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
no fair-queue
clock rate 2000000
interface Serial0/3/1
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
interface Vlan202
ip address 10.10.201.1 255.255.255.0
router ospf 1
no ip http server
disable-eadi
control-plane
voice-port 0/2/0:23
direct-inward-dial
dial-peer voice 2 voip
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.11
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 voip
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.10
no vad
dial-peer voice 911 pots
destination-pattern 911
port 0/2/0:23
forward-digits 3
dial-peer voice 7 pots
translation-profile outgoing 7
destination-pattern 9[2-9]......
port 0/2/0:23
forward-digits 7
gatekeeper
shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
login
ntp server 10.10.110.1
end
08-19-2013 04:02 AM
voice-port 0/2/0:23
exit
exit
exit
