07-01-2008 08:17 AM - edited 03-15-2019 11:39 AM
After you set this to true, on CM 5.1.3 do you have to restart any services or reboot the PUB?
07-01-2008 08:21 AM
Many parameter settings require the restart of the Call Manager service.
It is a good practice when changing or setting service parameters, to restart the call manager service to assure the new setting takes effect.
07-01-2008 08:52 AM
AAR parameter does not require a reset.
Chris
07-01-2008 09:02 AM
What then would prevent AAR from working? I had our vendor review my config.
1. Have AAR group setup
2. Have PT setup for AAR-PT
3. Have CSS setup for AAR-CSS
4. Have an LD route pattern under AAR-PT
5. AAR-PT is only PT in the AAR-CSS
6. AAR-CSS is applied to device level
7. Correct AAR group setup on line level
CAC is working with showing on phone screen that there is not enough bandwidth etc. Call never goes out. Call route is from remote office IP phone to Hub home office IP phone.
07-01-2008 11:55 AM
do all phones have the external phone number mask?
are you doing this within phones in the same cluster?
look into a CUCM trace, you will see if the call is attempted and what is dialed.
are you adding the necessary prefix to dial thru PSTN?
javalenc
if this helps, please rate
07-02-2008 04:08 AM
Yes all phones have an external phone mask
Yes phones are in same cluster, different locations physically and in CM
I never see the call attempted. In CUCM trace the last insert was about the display to the calling party of "Not Enough Bandwith".
You. The AAR group contains a 91 for prefix and long distance. There is a 91[2-9]xx[2-9]xxxxxx in the AAR-PT.
07-02-2008 04:55 AM
After you see on the phone "Not Enough Bandwidth" do you see "Rerouting"
07-02-2008 04:56 AM
No I don't, not in the CCUM logs.
07-02-2008 05:02 AM
In that case AAR is not kicking in, maybe you do need to restart the CM service.
07-02-2008 10:29 AM
Ensure that the GW is in the correct Location as well, the remote location GWs need to be configured with that "Location" for AAR to work properly.
HTH,
Chris
07-02-2008 11:19 AM
They are in the same location.
07-07-2008 03:53 AM
There is a Service Parameter on Callmanager called "Stop Routing on Out of Bandwidth Flag" by default this is set to False, change this to True and it may resolve the problem.
07-07-2008 04:20 AM
That is one I haven't heard of. I have a case open with Cisco and that is more than they have come up with. I will run this by them. I am rating this one for just thinking outside the box here....Will follow-up on what happens...
07-07-2008 07:26 AM
We are using a single cluster with separate sites for locations to enable AAR. I read the description, and it has to do more with trunks and between clusters, which doesn't apply here.
Stop Routing on Out of Bandwidth Flag: This parameter determines routing behavior for calls through intercluster trunks when not enough bandwidth exists. Valid values specify True or False. When the parameter is set to True and a call that is being routed to a remote Cisco cluster through a route list is released by a remote Cisco CallManager because of the insufficient bandwidth of a destination device at the remote cluster, a local Cisco CallManager will stop routing the call to the next device in the route list. When the parameter is set to False, the local Cisco CallManager will route the call to the next device. An associated Location specifies the bandwidth of the device.
This is a required field.
Default: False
07-07-2008 07:52 AM
My previous post should have read:-
Stop Routing on Out of Bandwidth Flag, default = true, try changing it to false, not the other way round.
I don't believe this only applies to ICTs.
Thanks for my first rating.
