Community Member
AAR Settings on Phone
Why would we use configure the --> AAR Destination Mask & AAR group under AAR settings on the line
    VS using
    the External phone number mask on the line and AAR group of the device.
    Is there a good logical explanation?
    1 ACCEPTED SOLUTION
    Hall of Fame Super Silver
    You do not have to configure AAR Destination Mask if you want the destination to be the same as the External Phone number mask, but this gives you flexibility to enter something different.  AAR Group is required on both DN and Device as Device level control outbound AAR and Line controls Inbound AAR, i.e. phone invoking AAR feature, and DN that needs to be redirected.
    HTH,
    Chris
    HTH,
    Chris
    Community Member
    Thank you
    By the way have you got the document/ link reference that details your summary
    HTH,
    Chris
    599
