03-06-2008 05:29 AM - edited 03-15-2019 09:16 AM
I`ve configured AAR so that phone A has been allocated AAR GRP A, Phone B AAR Group B
Phone A MASK 441615551000 AAR Group A, Location A, AAR CSS full access
Phone B MASK 12125551000 AAR Group B, Location B, AAR CSS full access
To dial Phone B from A I dial Telco 90012125551000 so due to this I have created an AAR group B with 900 in the Dial prefix to A
Testing
I modified the Location setting of B to 1KBP so to force AAR in place but when I make the call I get "Call can not take place ....." Is it the location B which is Allocated to B or do I reduce A ?
The only other part is that I use site codes to call A to B but with AAR if the call fails due to BW then it replaces the site code with the Mask ?
Any Idea`s
03-06-2008 10:30 AM
have you enabled AAR thru the parameters?
does the GW is also part of the AAR group?
the number that AAR will dial is going to be the AAR prefix + external phone number mask.
that number needs to be routable thru the PSTN
javalenc
03-07-2008 07:45 AM
Thanks for the reply, The GW has the same AAR group as Phone A i.e. it inserts 900 to the external mask- same as the phone. AAR is set to true as well
