Silver
AAR settings
I`ve configured AAR so that phone A has been allocated AAR GRP A, Phone B AAR Group B
Phone A MASK 441615551000 AAR Group A, Location A, AAR CSS full access
Phone B MASK 12125551000 AAR Group B, Location B, AAR CSS full access
To dial Phone B from A I dial Telco 90012125551000 so due to this I have created an AAR group B with 900 in the Dial prefix to A
Testing
I modified the Location setting of B to 1KBP so to force AAR in place but when I make the call I get "Call can not take place ....." Is it the location B which is Allocated to B or do I reduce A ?
The only other part is that I use site codes to call A to B but with AAR if the call fails due to BW then it replaces the site code with the Mask ?
Any Idea`s
Re: AAR settings
have you enabled AAR thru the parameters?
does the GW is also part of the AAR group?
the number that AAR will dial is going to be the AAR prefix + external phone number mask.
that number needs to be routable thru the PSTN
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
Silver
Re: AAR settings
Thanks for the reply, The GW has the same AAR group as Phone A i.e. it inserts 900 to the external mask- same as the phone. AAR is set to true as well
512
