AAR
asif.rehman
Dear All,
I need to implement AAR. There are two separate clusters connected by Intercluster trunk Is it possible in this scenario ?
gogasca
Level 10
Level 10
What you need here is a GK and an ICT GK Controller trunk.
So in the pattern pointing to the remote cluster you create a RL containing the ICT and then the PSTN.
thats the way to achieve redundancy.
AAR is location based and between IP Phones in the SAME cluster.
Thanks for the input.
