Abbreviated Dialing
I can configure Abbreviated Dialing in the cisco call manager v. 6?
Hall of Fame Super Silver
Re: Abbreviated Dialing
Sure.
Chris
For example, that 5554 is the phone number dialed by the user as #777
Abbriviated dialing is a feature on CM that allows users to dial their personal speed dials entered in the ccmuser page. What you are referring to is essentially global speed dial. The easiest way to accomplish that is to use translation patterns, so in your example you would have a TP with DN #777 that is configured to transform called number to 5554.
HTH,
Chris
Thanks, Chris , but there is some document about the configuration of this configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_1_3/ccmcfg/b03txpat.html
It applies for your ver as well.
Pretty much you just need the Translation Pattern field and the Called party transform mask field, and finally assign a CSS that can reach the Partition of the called party (Route Pattern or DN).
Thanks jbarcena !!!
481
