about call manager 7 and mirror
I just wonder how to set up RAID as Mirror on a call manager 7 server?
When I build the server, it doesnt really have option to select the RAID.
it seems that there is active partition and inactive partition that you can switch the version ... however.. how to set up Mirror?
Kind regards
Rachel
1 REPLY
Re: about call manager 7 and mirror
The RAID is automatically set up as part of the installation. The partitions are part of the logical disk. The exact RAID config depends on the platform. The RAID configuration information can be found in the installation guide in Table 9 RAID Settings:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_0_1/install/cmins701.html
The active and inactive partitions are there for upgrading. The inactive partition is upgraded, and after the upgrade, the partition states are swapped. If the upgrade has issues, or undesired results, you can revert back to the previous version.
Hope this helps,
Robert
175
