11-13-2013 07:20 AM - edited 03-16-2019 08:22 PM
Hi!
I have a few questions;
Currently I have a Call Manager which services as IVR on Cisco 2921. They need to change the SRST mode. The question is: SRST mode stop working the IVR?.
And in another case;
If the IVR stop working: What command is used to redirect the call to an annex (DN) specific?
regards
Solved! Go to Solution.
11-13-2013 07:27 AM
Use "CME as SRST" rather than SRST in which case you can continue using B-ACD/AA router functionality.
Chris
11-13-2013 07:27 AM
Chris
11-13-2013 07:41 AM
Thanks for your answer.
You mean the command "mode auto-provision srst" instead of using the "call-manager-fallback?
regards
11-13-2013 07:43 AM
It's all here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html
HTH, please rate all useful posts!
Chris
