about MCID ( Malicious Call ID )
hi !
we want to block Malicious Call from user's ip phone.
from cucm manual , i saw MCID feature.
but i have a question. after user pressed Malicious Call softkey , will cucm block Malicious call was pressed by user ?
thanks.
Hi Nivanak,
Using the Malicious Call ID Feature with Cisco Unified CallManager:
The MCID feature provides a useful method for tracking troublesome or threatening calls. When a user
receives this type of call, the Cisco Unified CallManager system administrator can assign a new softkey
template that adds the Malicious Call softkey to the user’s phone. For POTS phones that are connected
to a SCCP gateway, users can use a hookflash and enter a feature code of *39 to invoke the MCID feature.
When the MCID feature is used, the following actions take place:
1. The user receives a threatening call and presses the Malicious Call softkey (or enters the feature code
*39).
2. Cisco Unified CallManager sends the user a confirmation tone if the device can play a tone—and a
text message on a phone that has a display—to acknowledge receiving the MCID notification.
3. Cisco Unified CallManager updates the CDR for the call with an indication that the call is registered
as a malicious call.
4. Cisco Unified CallManager generates the alarm and local syslogs entry that has the event
information.
5. Cisco Unified CallManager sends an MCID invocation through the facility message to the connected
network. The facility information element (IE) encodes the MCID invocation.
6. After receiving this notification, the PSTN or other connected network can take actions, such as
providing legal authorities with the call information.
You can refer the CUCM admin guide for more information.
Hope it helps.
Anand
Please rate helpful posts..
hi !
thanks for ur answer.
but, can i  block Malicious Call with MCID ?
i read it, already but i do not understand flow after registered as malicious call.
Hi Nivanak,
Blocking incoming calls from MGCP
Method 1: (if you are using the MGCP gateway)
Blocking Particular Incoming call
Example: You need to block 0431183951
Gateway Incoming CSS: PSTN_CSS
Phones CSS: Phone_CSS
Make a new partition: Block_Partition
Add this new Partition to the Gateway CSS
I.e: PSTN_CSS---- Block_Partition
Make a Translation Pattern: 0431183951
Put in the Partition Block_Partition
Choose the "Block This pattern" option.
Restart all the devices.
Explanation:
Call comes into the gateway with Calling Info: 0431183951 The TP are searched first, the gateway see that the Block_Partition is the PSTN_CSS, so will send the call to TP. The TP matches the number, then blocks the calls. But if some other number comes in, the TP will not match and route the call.
But because most of times outgoing calls to 0431183951 should be allowed, we are not adding the phone partition to the TP and also not adding the Block_partition to Phone_CSS.
Method 2: (If method 1 not working properly)
starting from callmanager 4.0 or above, our development introduced a new feature Malicious Call Identification.
Malicious Call Identification :
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ed117.html
1. The user receives a threatening call and presses the Malicious Call softkey (or enters the feature code *39).
2. Cisco CallManager sends the user a confirmation tone if the device can play a tone—and a text message on a phone that has a display—to acknowledge receiving the MCID notification.
3. Cisco CallManager updates the CDR for the call with an indication that the call is registered as a malicious call.
4. Cisco CallManager generates the alarm and event log entry that has the event information.
5. Cisco CallManager sends a MCID invocation through the facility message to the connected network. The facility information element (IE) encodes the MCID invocation.
6. After receiving this notification, the PSTN or other connected network can take actions, such as providing legal authorities with the call information.
Hope it helps,if it doesn't work then you need to call the service provider (Telco) to block that specific incoming number.
Hope it helps.
Please don't forget the rate the helpful posts, by clicking on the stars below the helpful answer and mark as answered if it has answered your queries.
Anand
713
