Community Member
about networkd-clock-participate
Greeting, i need help with configuration about network-clock. Look my scenario.
1 2851 with 2 E1
E1(A) Used only for incoming calls
E1(B) Used for incoming and outgoing calls
E1(A)
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
debounce-time 10
answer-signal group-b 1
dnis-digits min 1 max 4
E1(B)
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
But the Slip Secs and Errored Secs is increasing in Wic 0
if I insert the command network-clock-select 2 E1 0/0/0 the errors increase.
I read about network-clock-participate, i try remove it from Wic 0. but appear this message.
VGCOOMEX001(config)#no network-clock-participate wic 0
%At least one ds0-group was configured already for E1 0/0/0.
Please remove it before changing timing mode.
Anyone can help me ?
Hall of Fame Super Gold
Re: about networkd-clock-participate
E1 0/0/0 goes to PSTN.
E1 0/1/0 goes to what ?
Community Member
PSTN too .... but E1(a)[[3037XXXX]] is only for incoming calls
E1(b)[[3014XXXX]] is used for incoming and outgoing
Different telcos ?
If so, chances are you will never eliminate slips off one interface and will have to live with that. Generally they are a problem for fax only.
318
