About Sip Secondary Dial Tone on CME
Hi All,
I installation 9971 SIP Phone on CME.
if I config:
telephony-service
secondary-dialtone 0
this is only support SCCP Phone.
How can configuration SIP phone secondary dial tone on CME?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Many, many features are not supported on SIP phones.
For this reason, is much better to use only SCCP phones.
Re: About Sip Secondary Dial Tone on CME
Oops. Cisco 9971 IP Phone only support SIP........
Correct. Otherwise I would have said "Phones in SCCP mode", or "switch to SCCP firmware".
Thank you for the nice rating and good luck!
 From Cisco Unified CME
 From Cisco Unified CME Release 11.6 onwards, secondary dial tone is supported on both SIP phones and SCCP phones.
Example for Configuring Secondary Dial Tone on SIP Phones
A secondary dial tone is played on the phone when comma (',') is found in the pattern. In this example, secondary dial tone is played after the digit 50.
voice register dialplan 1
 type 7940-7960-others
 pattern 1 50,
voice register pool 1
 busy-trigger-per-button 2
 id mac 0C11.6780.52A3
 type 7841
number 1 dn 1
 dialplan 1
 dtmf-relay rtp-nte
 username cisco1 password cisco
 codec g711ulaw
 no vad
 provision-tag 1
978
