Abreviated Dailing
Please  i m new to voice and would like to know wht does abbreiated dailing means.
Hall of Fame Super Silver
Abreviated Dailing
Abbreviated Dialing means to dial a specified number (speed dial) to reach a predefined assigned destination.  You add abbreviated dials via ccmuser page for example and invoke it via the AbbDial sofkey, then enter the assigned number to trigger the speed dial.
HTH,
Chris
Abreviated Dailing
Thanks for your response.
Kindly can you please me know what does globalized and normal numbering means.
Abreviated Dailing
This is well described in CUCM SRND, in a nutshell Globalization means that you format the number into a full +e164 form, such as +12125551234 for US numbers for example as calls arrive to the system, as well as your normalize the dialed numbers as they are dialed.
HTH,
Chris
Abreviated Dailing
Thanks for your reply.
Can you please eloborate more on "as well as your normalize the dialed numbers as they are dialed.".
I appreciate your patience on my naive questions.
Hall of Fame Super Gold
Abreviated Dailing
Let's just say you assign "11" to dial your home number.
You enter "11" in your keypad and press Abbreviated Dialing, then the phone will know what number to dial.  It's like speed dial.
227
