Accept Collect Calls E1 R2 with country Brazil use-defaults
All,
I set up a controller E1 with country brazil use-defaults. When I receive a collect call from PSTN, this call has category II-8 and the cisco voice gateway returns B-7, disconnecting the call. I find this feature "E1 R2 Collect Call Blocking".
I need accept collect calls from PSTN with category II-8 and can´t find a way to disable this feature !!!
New Features
E1 R2 Collect Call Blocking Feature
The  E1 R2 Call Blocking feature provides two ways to block incoming collect  calls-category-based and double answer. With category-based call  blocking, collect calls will be blocked based on a specific category.  For example, in Brazil, collect calls arrive with a category II-8, for  which the Cisco access router will send B-7 as a response instead of an  answer signal. This approach is only applicable when switches in the  central office support category-based blocking.
Router:3825
IOS:c3825-advipservicesk9-mz.124-24.T4.bin
Controller config:
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  metering
  category 2
  answer-signal group-b 1
  trunk-group PSTN timeslots 1-15,17-31 preference 1 description EMBRATEL CIRCUITO (1)
Does anyone have any tips that can help me?
Thanks and Regards.
Guilherme Lonardoni
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
That is a completely undocumented command, in perfect Cisco style.
Thanks for letting us know!
Re: Accept Collect Calls E1 R2 with country Brazil use-defaults
try to disable the double answer:
Router(config)# controller e1 4/0
Router(config-controller)# cas-custom 1
Router(config-controller)# no double-answer
Regards!
Leonardo Santana
Double-answer is disabled by default.
May be OP can try enabling it, to possibly prevent the router to reject the call with category-based signal.
Thanks, but double-answer is not configured.
Disconnection occurs based on category.
I solved problem with command collect-call-enable under cas-custom.
Thanks all.
Hi Guilherme !
I have another situation with Collect Calls.. I need to allow the incomming collect calls, but, the calls are comming from PSTN to a Philips PBX first... than, to a cisco gateway.. it would be like this:
PSTN > PBX > E1 ISDN QSIG > C2951 > CUCM7.x > IP Phone.
When I pickup the call, I start hearing the music.. but the call is droppend in a second....
any idea ?
Thank you !
Andrei.
1964
