Community Member
Acceptable value of RTD for IP Phone to work over WAN
I am using callmanager 6.1. Can i place ip phones over internet link where the rtd is too high. Whats the acceptable value of RTD for the IP Phone to work over WAN.
Thanks.
Hall of Fame Super Gold
Re: Acceptable value of RTD for IP Phone to work over WAN
Hi, RTTs of 800+ ms are common for sites via VSAT, phones be used normally and really not an issue. I recommend g711 on these links unless you can do iLBC.
Community Member
Thanks for your response. But over WAN or MPLS whatever the scenario may be if the RTD is 800+ then if you press the "New Call" softkey in your phone you will get the dialtone after 2secs which will indicate the delay. Moreover over WAN codec will be g729 rather g711.
How does g729 codec affect the phones....
Silver
Is there any guide lines for Call Control. I`m looking to configure a remote site so that voice traffic is via the local Telco but call control is via a WAN- what delay for Call Control can I get away with
thanks
Clustering Over the IP WAN
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/6x/models.html#wp1043996
maybe this helps
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
409
