Accepting calls only from registered devices
antonio.guirado
Level 3
Level 3
I am working to create a SIP trunk in CCME 8.6 (c2851) and an ASTERISK server. Everything is fine but I have a doubt.
For incoming call to CCME (ASTERISK to CCME), Cisco always accepts calls even if ASTERISK server is not registered.
There is no security or authentication. I do not want encryption but I want that Cisco only accepts SIP calls from ASTERISK server.
I suppose that you can use ACL's but my question is "Is there anyway to configure a Cisco CCME that only accept calls from
registered devices?".
May be you can try with IP address trusted list feature which is available from 15.X IOS
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmetoll.html
//Suresh Please rate all the useful posts.
thank you very much. I have jast tried and it works.
Regards.
Hi Antonio, good to hear that everything works as expected. Glad to help.
Cheers
Suresh
