Access logs for CUCM 5.1.3 MLA
Do you know how to view the access logs for CUCM 5.1.3 MLA?
Thank you,
Ricky
1 ACCEPTED SOLUTION
Re: Access logs for CUCM 5.1.3 MLA
you would need to enable the following trace:
Cisco Role-based Security
and you can use RTMT to get them, this as with previous versions only shows who logged in, not what changes were made by the user
java
if this helps, please rate
www.cisco.com/go/pdi
java
Thanks, i was able to view the logs now.
152
