ā02-14-2012 07:24 AM - edited ā03-16-2019 09:35 AM
Hi Everyone,
Just a quick question or possibly confirmation regarding the Cisco 7921 IP Phone. I am wanting the purchase the mentioned IP Phone however, the documentation/data sheet doesnt indicate support for a Cisco Aironet 1041 Access Point, which I have. It seems that the IP Phone has support for older access points, however, not the 1041. Just wondering if someone can possibly confirm this for me?
Note: The 1041 access point that I have is not the LAP version (no controller card), just the stand alone access point (AP).
Thanks in advance.
Dennis.
Solved! Go to Solution.
ā02-14-2012 08:05 AM
Hi Dennis
I see no reason why it shouldn't work. The 7921 should work with any WiFi compliant IEEE 802.11b/g access point (both Cisco and otherwise).
Please be aware that the 7921 is now end of sale.
Replacement is the 7925.
HTH. Barry
ā02-14-2012 05:01 PM
WAP 1040 will support 7921. IT's not stated because no one bothered raising this issue with Cisco (use the "Feedback" link found in the lower left-hand corner). Cisco documentation team are normally very quick to respond (within 3 hours) by sending you an email just to clarify what your complaint is all about.
Hi Dennis
HTH. Barry
