Access ristrictions
michalis1234
How can i gain access to uc migration section
There used to be a section called UC migrations under Collaboration, Voice and Video space, after the new image it's not there, that's what he's asking.
Have no idea if it was removed, or moved to some other place.
java
if this helps, please rate
Chris Deren
Can you elaborate what section are you referring to?
Chris
java
michalis1234
It is almost one week now that i experience difficulties in finding information. I hope cisco will finish this new deployment soon.
Rob Huffman
Hi there,
You can still get to UC Migrations from the Main Directory at the top of the page. Not sure why it isn't listed
directly under Collaboration, Voice Video.
Cheers!
Rob
