Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Access to the Product Upgrade Tool?
I have a question about access to the Product Upgrade Tool (PUT).
I know that if you have UCSS with your contract you have access to PUT.
Is UCSS required to use PUT?  Or can I have a standard smartnet (for CUCM servers) and still gain access to PUT?
The ordering guide isn't explained nicely, so I'm looking for a better less-confusing explanation.
What requirements are needed to gain access to PUT?
Thank you!
-rya
Everyone's tags (4)
1 REPLY
Hall of Fame Super Red
Hey Rya,
You will need SASU contract support at a minimum
Cisco Software Application Support plus Upgrades (SASU)
Provides all of the same features as SAS plus major  software application upgrades. Upgrades provide a richer feature set and  improved performance and efficiency.
http://www.cisco.com/en/US/products/svcs/ps3034/ps2827/ps2993/serv_group_home.html
You can send an email to determine your access rights to PUT (see below)
From the PUT Q&A
9.) What is required to obtain access to the Product Upgrade Tool?
Only registered users with a Cisco.com account and contract entitlement can use this tool. If you are unable to access the Product Upgrade Tool, send an e-mail to cs-support@cisco.com with the keyword PUT-ACCESS in the subject line of the e-mail. Be sure to include your CCO userID and applicable contract number.
http://www.cisco.com/en/US/customer/applicat/upgradet/applications_qandas.html#rt9
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
8183
