06-03-2014 08:57 AM - edited 03-16-2019 10:58 PM
We have 40+ Cisco IP Phone 7965, and an administrator in our office wants to know if he can access the database of any user's call history, e.g. wants to know what calls I made and received from any specific dates in the past. I was thinking it could be done through the Cisco Unified CM Administration web interface, but I don't know where to look at. Please let me know if this is possible.
Thanks.
06-03-2014 09:11 AM
No, you want to do that from CAR, not from CCMAdmin. Go to serviceability to find it, assuming you have it enabled.
06-03-2014 09:23 AM
Hi and thanks for the prompt reply.
The serviceability in the CCMAdmin?
06-03-2014 09:25 AM
Use the dropdown from top right corner.
06-03-2014 09:36 AM
One of them says Cisco Unified Serviceability. Once I click on it, where do I go?
06-03-2014 09:36 AM
+5 to Jaime... or you can use below URL to get the same.
http://<IP address of CUCM>/car
Suresh
06-03-2014 09:38 AM
Hi Suresh,
Ok thanks for the link. Where do I go to check on call reports from a user?
06-03-2014 09:43 AM
Click on "CDR" then "Export CDR/CMR" and then check "CDR Records" and select the duration. You will get this CDR info in text format and after that you can open it using Notepad ++ and you can analyze it.
Suresh
06-03-2014 10:02 AM
06-03-2014 10:02 AM
Read the documentation for CAR, or play with it, getting reports is not that hard
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/10_0_1/car/CUCM_BK_C885BA46_00_cdr-analysis-reporting-administration-100.html
06-03-2014 10:51 AM
I figure it out how to search the CDR of a single user. Question is, how far back can I go? Does the data deletes itself after a certain amount of days in the system?
06-03-2014 11:04 AM
The maximum time data will be stored is 180 days, if you need to keep it for longer periods of time, you need to configure a billing server to hold the data, and also a 3rd party billing server as we only export the raw data.
The default is just 60 days for keeping records.
06-03-2014 12:22 PM
Is the billing server also in the CAR? Or is it something that is outside of Cisco?
06-03-2014 12:42 PM
You can use any FTP server or you can get an actual 3rd party billing server with a pretty web interface for management to use.
Rather than exporting all the CDR, you can also just search for a certain extension under CDR->Search->By User/Phone Number. You can then enter their extension and press the "Add Phone Number" button and then set the time range.
06-03-2014 12:43 PM
To configure a billing server, go to CDR management, setting up the SFTP server to receive the CDR flat files, is up to you.
