accessing CUE http
davieshuw
Hi. i remember that when I implimented my CUE module on my UC520, if I went to the CUE module IP address in IE, i'd get all the CME stuff, plus the CUE html too.
Ive got a 2801 now, and i've implimented the CCME html and that works OK, but when I go to the CUE IP address, nothing loads. Where shall I start!
2 Accepted Solutions
paolo bevilacqua
If CUE's address is take from voice or data vlan as usually happens, you should have a route like x.x.x.x 255.255.255.255 se0/0. This in addition to correct config under se0/0.
Davie, "no shutdown" will help you a lot.
paolo bevilacqua
Hi mate.
I've decided not to go with VLAN's on this implimentation as its only a small set up (and fancied a change)
I've configured:
interface Loopback0
ip address 192.168.150.1 255.255.255.252
interface Service-Engine0/0
ip unnumbered Loopback0
shutdown
service-module ip address 192.168.150.2 255.255.255.252
service-module ip default-gateway 192.168.150.1
ip route 192.168.150.2 255.255.255.255 Service-Engine0/0
ah... thats rather embarrasing!
(..picks up ICND 1 for Dummies)
Thanks man!!
