Accessing unity Voice Mail from an External Phone
I have Cisco Unity 5 integrated with CUCM6 and was wondering how I set up unity to allow a user to access their voice mail from an external phone, say their Mobile or home phone?
Help rated.
Gavin
Hall of Fame Super Red
Re: Accessing unity Voice Mail from an External Phone
Hi Gavin,
You can setup the Cell# and Home# as Alternate Extensions for the Subscriber mailbox. Have a look;
Setting Up Alternate Devices
In addition to your primary extension, your Cisco Unity administrator may set up alternate extensions for you, and may also allow you to do so in the Cisco Unity Assistant. Administrators set up alternate extensions for various reasons, such as handling multiple line appearances on subscriber phones or simplifying message addressing for subscribers on different Cisco Unity servers.
You may want to use alternate extensions to make calling Cisco Unity from an alternate device, such as a cell phone, a home phone, or a phone at another work site more convenient. When you specify the phone number for an alternative device in the Cisco Unity Assistant, Cisco Unity handles all calls from that number in the same way that it handles calls from your primary extension (assuming that the alternate phone number is passed along to Cisco Unity from the phone system). This means that Cisco Unity associates the alternate phone number with your account, and when such phones are set to forward to Cisco Unity, callers can listen to your greeting, and leave messages for you, just as they would when dialing your primary extension.
Depending on how Cisco Unity is set up, you may be able to use the Personal Preferences page in the Cisco Unity Assistant to:
View the alternate extensions that your Cisco Unity administrator specified for you.
Specify phone numbers for up to five alternate devices, in addition to those that your Cisco Unity administrator specified for you.
Do the following procedure to set up alternate devices in the Cisco Unity Assistant.
To Set Up Alternate Devices
Step 1 In the Cisco Unity Assistant, on the Preferences menu, click Personal.
Step 2 In the Alternate Devices table, enter an extension up to 30 characters in length in the Number field.
When entering numbers in the Alternate Devices table, consider the following:
Each alternate extension that you add must be unique; Cisco Unity will not accept an extension that is already assigned to another subscriber (either as a primary or alternate extension) or to another Cisco Unity entity (such as a public distribution list).
Enter digits 0 through 9. Do not use spaces, dashes, or parentheses.
Step 4 To specify another device, click the Add Row button and repeat Step 2 and Step 3.
Step 5 Click Save. The alternate devices you specified are enabled for all rows in the table.
From this good Unity doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_user_guide_chapter09186a00806404ff.html#wp1125142
Hope this helps!
Rob
Super Bronze
Hi Gavin
The first step is to get a number on your system that is diallable from outside the company, and route it to Unity..
If your current VM Pilot number isn't accesible, put in a translation pattern to translate a DDI number to your VM Pilot.
When you dial it, as Unity doesn't recognize the number, it will give you the standard greeting. You can hit * to get the login prompt, where you can enter your userID and PIN to get your VM.
You can make this easier for users if you want by adding their external numbers as 'Alternate Extensions'. This would make Unity recognise their number when the call comes in, and just ask for their PIN.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
629
