09-29-2011 12:37 AM - edited 03-16-2019 07:14 AM
I need to create dial extinction (for example 4000), and external (PSTN) number used to connect to your DN and listen to your voice messages box.
Ali
09-29-2011 07:19 AM
Hi.
Are you in CUCM or CUCME envirorment?
Anyway you should be able to reach VM pilot number from the PSTN working, in case of CUCM, with partition and CSS.
Please let us know
Bye
Carlo
09-29-2011 09:49 AM
09-29-2011 02:20 PM
Create another voicemail pilot using one of your DID extensions and point it to the same voicemail system. I am assuming you are using some variant of Cisco Unity for voicemail.
