Community Member
Accessing voicemail from another users phone - CME
Voicemail pilot number 1000
Is there a way to configure cme/cue to access your voicemail from another persons phone, I notice by default when you dial into voicemail it uses the extension you dial from to check whether there is a mailbox and if so asks for a password.
Is there a way to enter the voicemail box number you want to check
Thanks in advance
1 ACCEPTED SOLUTION
VIP Purple
Re: Accessing voicemail from another users phone - CME
Yes, when CUE picks up, press *.
Hope this helps. If so, please rate the post.
Brandon
VIP Purple
Brandon
Community Member
Excellent exactly what I was looking for.
You wouldnt happen to have a link to that Brandon ?
Many Thanks
Mark
VIP Purple
Mark,
Take a look at the CUE User's Guide below.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_user_guide09186a00806033eb.html#wp1049296
Hope this helps.
Brandon
838
