Activate a call forward with a Third-party SIP Device or with a analog device
In a CUCMv9, how i can activate a call forward (all, busy, no anwser...) with Third-party SIP Device or with a analog device connected to a fxs?
I want to activate a call forward like a Alcatel or Aastra PBX with a code.
For exemple, i pick up the phone, with the code *95 followed by the destination number and hangs up the phone. And use the #95 for désactivate this call forward.
It's possible?
Thanks.
Jaime Valencia
No codes for 3rd party SIP phones, no way to do it. Or for that matter, not even for Cisco Phones, other than CFA.
Anything besides CFA needs to be done via CCMadmin or CCMuser for any kind of phone.
For FXS that's only doable if you're running SCCP
http://www.cisco.com/en/US/partner/docs/ios/voice/fxs/configuration/guide/fxssccpsplmft.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
ok, thanks
Are there updates/enhancement in recent versions of CUCM to support Call forward by 3rd party? Could a 3rd party use SIP 302 to redirect the call in lieu of a CFA on the line in CUCM?
