Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Active Directory Plugin. CM 5.x and 6.x
Does anyone have a link for installing CM 5.x and above with AD.
Is it still the same procedure as using the AD Plugin?
Customer has new cluster site that will install 5.x then upgrade to 6.0. New this to be an AD database instead of LDAP.
Then another site with 4.x LDAP that will be upgraded and migrated into the new cluster (AD)
Any links/inputs will he helpful.
Hall of Fame Super Red
Re: Active Directory Plugin. CM 5.x and 6.x
Hi Majid,
Here a some docs to get you started;
Cisco Unified CallManager System Guide, Release 5.0(1)
Understanding the Directory
The following list summarizes the changes in directory functionality from previous releases of Cisco CallManager:
The directory component has been decoupled from Cisco CallManager to ensure high Cisco CallManager availability independent of the corporate directory.
Cisco CallManager and related applications store all application data in the local database instead of in an embedded directory. The embedded directory gets removed and Cisco CallManager supports synchronization with the customer directory.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008037e2d0.html
LDAP Directory Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008037e997.html
LDAP System Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008037e99a.html
Hope this helps!
Rob
Hall of Fame Super Silver
The AD integration on CM 5.X and 6.X architecture has gone through a major redeisgn. You no longer need to run a pluging the integration is as simple as enabling the DirSync service and configuring the LDAP settings under system menu. It is drastically easier than CM 4.X and prior versions.
Chris
220
