AD Change - LDAP Impact?
UCM 5.1(3) with LDAP integration configured. We're moving object within the AD to a new OU.
example
DC=MAIN, DC=ABCCORP, DC=COM
old: OU=STAFF,
new: OU=USA, OU=USERS, OU=STAFF
What behavior should be expect when we create the new LDAP User Search Base and move the accounts? The next time the LDAP is synced will is purge the directory and reimport the accounts, or recognize they are the same account and leave them as they are?
Thanks in advance,
Brian
Re: AD Change - LDAP Impact?
CUCM uses the attribute you set as primary to sync the accounts so if you do not change any of those, user info won't be purged and will be kept
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Where is this "primary" attribute you're referring to?
I do not see any reference in the LDAP options in UCM.
Thanks in advance,
Brian
when you configure the LDAP you configure this:
LDAP Attribute for User ID
that is the one DirSync compares to know if the user is still active or should be deleted.
javalenc
java
I'm trying to do something similar and I just wanna confirm...
We have our LDAP pointed to the global level and we have a lot of extra Admin users etc in our corp directory...so we moved all phone users to a sub-directory under the global directory in ADS.
Can I add the new directory and remove the old global entry and will the phone users in the sub-directory not get removed and their phone associations and user group settings remain. (they have the same User ID attribute as sAMAccountName)
We have our AD directory set to
OU=Users,DC=adsgroup,DC=com
instead we want to use
OU=phoneusers,OU=Users,DC=adsgroup,DC=com
thanks in adv,
:JoeL
179
