04-03-2012 12:49 AM - edited 03-16-2019 10:26 AM
Hi All,
As per Subject, I'm unable to complete an ad-hoc conference.
I do the following:
1) call party 1
2) press confr softkey
3) call party 2
4) press select for call 1, press select for call 2, press Join softkey.
My DSP are registered:
CUCME#sh sdspfarm uni
mtp-1 Device:xcoder TCP socket:[9] REGISTERED in SCCP ver 18/18
actual_stream:0 max_stream 8 IP:10.200.20.120 * 29595 MTP Dixieland keepalive 11
Supported codec:
G711Ulaw
G711Alaw
G729
G729a
G729b
G729ab
Universal Xcoder
max-mtps:1, max-streams:0, alloc-streams:0, act-streams:0
SCCP is UP
CUCME#show sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
IPv4 Address: 10.200.20.120
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.200.20.120, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.200.20.120, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 8, Reported Max OOS Streams: 0
Debug Ephone hw-Conference
CUCME#deb ephone hw-conference
EPHONE hardware conference debugging is enabled
CUCME#
Apr 3 07:14:27.081: SkinnyHWConfAPI: reqType 14:Is Conf
Apr 3 07:14:27.081: SkinnySelectButtonPress: phone=5 dn=17 chan=2 dn_idx=306 ref=2803 line=1 ovl=1 select=1
Apr 3 07:14:29.149: SkinnyHWConfAPI: reqType 14:Is Conf
Apr 3 07:14:29.149: SkinnySelectButtonPress: phone=5 dn=17 chan=1 dn_idx=17 ref=2801 line=1 ovl=1 select=1
Apr 3 07:14:32.689: SkinnyHWConfAPI: reqType 14:Is Conf
Apr 3 07:14:32.689: SkinnyJoinButtonPress: party=2 master_conf=0 participant_conf=0
Apr 3 07:14:32.689: SkinnyJoinButtonPress: line=1 ovl=1 dn=17 chan=1 selected to join conf
Apr 3 07:14:32.689: SkinnyJoinButtonPress: New adhoc conf: Initial party 1(dn=17 chan=1)
Apr 3 07:14:32.689: SkinnySelectButtonPress: phone=5 dn=17 chan=1 dn_idx=17 ref=2801 line=1 ovl=1 select=0
Apr 3 07:14:32.689: SkinnyJoinButtonPress: line=1 ovl=1 dn=17 chan=2 selected to join conf
Apr 3 07:14:32.689: SkinnyJoinButtonPress: New adhoc conf: Initial party 2(dn=17 chan=2), ready to set up new conf
Apr 3 07:14:32.689: SkinnyHWConfAPI: reqType 1:New Conf
Apr 3 07:14:32.689: skinny_hwconf_new_adhoc_setup_video_call: Audio Ad-Hoc call
Apr 3 07:14:32.689: skinny_hwcfb_check_resource: for Audio
Apr 3 07:14:32.689: skinny_hwcfbi_find_next_mtpcb No conference MTPCB for device type 52:Audio only Fail
Apr 3 07:14:32.689: skinny_hwconf_new_adhoc_conf_setup: No MTPCB resources for Audio Call
Apr 3 07:14:32.689: SkinnyJoinButtonPress: New adhoc conf: new conf setup failed!
Apr 3 07:14:32.689: SkinnySelectButtonPress: phone=5 dn=17 chan=2 dn_idx=306 ref=2803 line=1 ovl=1 select=0
CUCME#
CUCME# sh ephone-dn conference ad-hoc
type active inactive numbers
Ad-hoc 0 2 A100
DN tags: 29
So I have the following checklist
1) SCCP is UP
2) DSPfarm is registered
3) ephone-dn for ad-hoc is configured
What am I missing that there are no resources for conferencing?
Felix
Solved! Go to Solution.
04-03-2012 12:54 AM
HI
You have confugured transcode instead of conference resource.
dspfarm profile 1 transcode universal
Configure
dspfarm profile 2 conference xyz
Ronak Patel
Please rate helpful posts.
04-03-2012 12:54 AM
HI
Configure
Ronak Patel
04-03-2012 05:08 PM
thanks Ronak!
how obvious is that?!
