Community Member
ad-hoc conference hardware "cannot complete conference"
Hi All,
As per Subject, I'm unable to complete an ad-hoc conference.
I do the following:
1) call party 1
2) press confr softkey
3) call party 2
4) press select for call 1, press select for call 2, press Join softkey.
My DSP are registered:
CUCME#sh sdspfarm uni
mtp-1 Device:xcoder TCP socket:[9]  REGISTERED in SCCP ver 18/18
actual_stream:0 max_stream 8 IP:10.200.20.120 * 29595  MTP Dixieland keepalive 11
Supported codec:
                 G711Ulaw
                 G711Alaw
                 G729
                 G729a
                 G729b
                 G729ab
Universal Xcoder
max-mtps:1, max-streams:0, alloc-streams:0, act-streams:0
SCCP is UP
CUCME#show sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
        IPv4 Address: 10.200.20.120
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.200.20.120, Port Number: 2000
                Priority: 1, Version: 7.0, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.200.20.120, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 8, Reported Max OOS Streams: 0
Debug Ephone hw-Conference
CUCME#deb ephone  hw-conference
EPHONE hardware conference debugging is enabled
CUCME#
Apr  3 07:14:27.081: SkinnyHWConfAPI: reqType 14:Is Conf
Apr  3 07:14:27.081: SkinnySelectButtonPress: phone=5 dn=17 chan=2 dn_idx=306 ref=2803 line=1 ovl=1 select=1
Apr  3 07:14:29.149: SkinnyHWConfAPI: reqType 14:Is Conf
Apr  3 07:14:29.149: SkinnySelectButtonPress: phone=5 dn=17 chan=1 dn_idx=17 ref=2801 line=1 ovl=1 select=1
Apr  3 07:14:32.689: SkinnyHWConfAPI: reqType 14:Is Conf
Apr  3 07:14:32.689: SkinnyJoinButtonPress: party=2 master_conf=0 participant_conf=0
Apr  3 07:14:32.689: SkinnyJoinButtonPress: line=1 ovl=1 dn=17 chan=1 selected to join conf
Apr  3 07:14:32.689: SkinnyJoinButtonPress: New adhoc conf: Initial party 1(dn=17 chan=1)
Apr  3 07:14:32.689: SkinnySelectButtonPress: phone=5 dn=17 chan=1 dn_idx=17 ref=2801 line=1 ovl=1 select=0
Apr  3 07:14:32.689: SkinnyJoinButtonPress: line=1 ovl=1 dn=17 chan=2 selected to join conf
Apr  3 07:14:32.689: SkinnyJoinButtonPress: New adhoc conf: Initial party 2(dn=17 chan=2), ready to set up new conf
Apr  3 07:14:32.689: SkinnyHWConfAPI: reqType 1:New Conf
Apr  3 07:14:32.689: skinny_hwconf_new_adhoc_setup_video_call: Audio Ad-Hoc call
Apr  3 07:14:32.689: skinny_hwcfb_check_resource: for Audio
Apr  3 07:14:32.689:  skinny_hwcfbi_find_next_mtpcb No conference MTPCB for device type 52:Audio only Fail
Apr  3 07:14:32.689: skinny_hwconf_new_adhoc_conf_setup: No MTPCB resources for Audio Call
Apr  3 07:14:32.689: SkinnyJoinButtonPress: New adhoc conf: new conf setup failed!
Apr  3 07:14:32.689: SkinnySelectButtonPress: phone=5 dn=17 chan=2 dn_idx=306 ref=2803 line=1 ovl=1 select=0
CUCME#
CUCME# sh ephone-dn conference ad-hoc
type         active inactive  numbers
Ad-hoc          0       2      A100
DN tags: 29
So I have the following checklist
1) SCCP is UP
2) DSPfarm is registered
3) ephone-dn for ad-hoc is configured
What am I missing that there are no resources for conferencing?
Felix
1 ACCEPTED SOLUTION
Blue
HI
You have confugured transcode instead of conference resource.
dspfarm profile 1 transcode universal
Configure
dspfarm profile 2 conference xyz
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
HI
Configure
Ronak Patel
Community Member
thanks Ronak!
how obvious is that?!
2330
