04-21-2009 03:16 AM - edited 03-15-2019 05:34 PM
Hi all,
I have CCM 5.1 configured with GW via H.323 protocol .. i have to configure Ad-hoc conference .. i have dsp of 24 channels,, after configuring the 1 session 7 dsps are utilizing for conference and rest for incoming and outgoing .... is there any way to configure Ad-Hoc conference by utilizing less number of dsps ????
04-21-2009 03:24 AM
conference demands a whole DSP, there is no way to change this.
even if you configure 1 session with G711 you'll use the whole DSP as the FW on it can only do CFB.
that of course depends of availability of DSPs, codecs configured and amount of sessions configured.
but bottom line, if a DSP is going to be used for CFB there is no other use for it
1 DSP are 16 channels, your calculations does not make sense.
java
if this helps, please rate
04-22-2009 10:56 AM
hi java
thanks for your nice explaination ...
i had pri with 20channels and after configured one conference session it reserves 7 and rest of 13 are available for configure on controller ...
04-22-2009 11:24 AM
As Java stated above you cannot share DSPs between voice ports and conferencing.
If you have 24 PVDM channels that means you have PVDM2-16 and PVDM2-8 modules, with that configuration and a full PRI in flex codec complexity mode you will not be able to allocate any DSP conference bridges.
You need to ensure you have a full DSP (PVDM2-16 = 1 DSP) allocated to conferencing.
Please provide "sh diag" and "sh run" from the router and we can tell you exactly what you can run.
HTH,
Chris
04-23-2009 03:10 PM
thanks guys below is the sh diag and sh run of router ...
TGRTR1#sh diag
Slot 0:
C2851 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11243QJ7
Hardware Revision : 1.0
Top Assy. Part Number : 800-26922-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20070621
Chassis Serial Number : FCZ113171Z0
Chassis MAC Address : 001c.584b.2bf8
MAC Address block size : 32
CLEI Code : COM7N00ARA
Product (FRU) Number : CISCO2851
Part Number : 73-8480-05
Version Identifier : V04
EEPROM format version 4
EEPROM contents (hex):
PVDM Slot 0:
48-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8540-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11296UCH
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-48
Version Identifier : V01
WIC Slot 0:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC1138371E
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
sh run
TGRTR1#sh run
Building configuration...
Current configuration : 8188 bytes
card type e1 0 0
ip cef
isdn switch-type primary-net5
voice-card 0
no dspfarm
dsp services dspfarm
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-20
controller E1 0/0/1
framing NO-CRC4
pri-group timeslots 1-13,16
ip tcp path-mtu-discovery
interface GigabitEthernet0/0
description ******** Connected to 4506 gig5/4 *******
ip address 172.16.20.5 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.20.5
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.20.254
voice-port 0/0/0:15
translation-profile incoming DID
voice-port 0/0/1:15
sccp local GigabitEthernet0/0
sccp ccm 172.16.20.2 identifier 1 version 5.0.1
sccp
sccp ccm group 10
associate ccm 1 priority 1
associate profile 10 register CFBTGRTR1
switchover method immediate
switchback method immediate
dspfarm profile 10 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
associate application SCCP
dial-peer voice 1 voip
translation-profile outgoing PSTNIN
destination-pattern 1...
session target ipv4:172.16.20.2
dtmf-relay h245-alphanumeric
codec g711alaw
no vad
thanks in advance
04-23-2009 08:53 PM
you have 48 channels, 3 DSPs
1 for CFB the other two are already being used for voice termination
you're out of channels
java
04-23-2009 11:55 PM
hi java,
thanks for your guide .... i will tell customer to increase the Dsp's ...
Java one more question if you have time can you please have a look on my other post having subject " H.323 GW for Branch Location " ...
can you please guide me urgently how to setup the network and fix out the calling issues ..
this is my first installation for configuring SRST Network & sorry to ask basic questions !!! plz help urgently if you can
04-24-2009 05:36 AM
It looks like you have only 1 conference session configured, you can safely change it to 2 as a DSP with high complexity codec listed (g729) can provide 2 conference sessions of up to 8 participants in each. So if you create 1 or 2 sessions it makes no difference as you are commiting full DSP to the conference resources anyway.
Another way to get more out of DSPs is instead of listing g729 in your conference profile is to only include G711, and add a transcoder with G711 and G729 listed. This way you can have 8 conference sessions and transcoding DSPs can be shared between voice sessions. Also, in most deployments most conferences are local which only use G711 anyway, and if remote party has to be conferenced in then the transcder is invoked.
HTH, please rate all posts!
Chris
