Community Member
Ad-Hoc Conferencing
I've setup Ad-Hoc conferencing on a 2811 running 12.4(15)T8 with CME 4.1.0.2. Using phone 1 I call phone 2 and then on phone 1 I place phone 2 on hold. Then I make a new call from phone 1 to phone 3. At that point I press conference on phone 1 and phone 2 and 3 are joined in a conference and phone 1 shows that it is connected to the extension that I have defined as the conference extension. However, I hear a busy signal on phone 1. Phones 2 and 3 can communicate back and forth just fine, but phone 1 doesn't become part of the conference. Phone 1 and 2 are on the same CME and phone 3 is on another phone system that communicates via H323. The conferencing is setup as hardware on the 2811 and I have enough PVDM2 resources to allow 6 sessions. I don't understand why phone 1 doesn't become part of the conference.
Hall of Fame Super Gold
Re: Ad-Hoc Conferencing
Hi, once you configure HW conferencing, ad-hoc stops working. My recommendation is that patiently you go over the config examples in the manual to find a possible mistake.
Hall of Fame Super Red
Hi Brandon,
Just a comment here on the methods used by the phone user to setup the Conference. This is normally done this way;
Phone 1 calls Phone 2
Phone 2 answers
Phone 1 Presses Conference Button
Phone 1 calls Phone 3
Phone 3 answers
Phone 1 Presses Conference Button a second time and all three calls are Conferenced together.
Just a thought :)
Rob
Community Member
Thanks for the response Rob. I've tried that method as well and the same thing happens.
Hall of Fame Super Silver
Are you using hardware or software conferencing here?
With CME software conferencing allows only for 3 parties, with hardware you can have up to 8.
If you are using hardware conferencing the most common ommision is the creation of conference ephone-dns, make sure you create these as described in the admin guide.
HTH,
Chris
445
